General Bluetooth ELM327 & FiatECUScan ...
after much playing, reinstalling the stack (harder than it sounds) worked, i now have a fully functioning Bluetooth management software set.....but....the connection is so skittish its unreal....i have to "re-connect" every minute or so, and when trying to connect to the can network i get "timed out" error...
i bought the same dongle as shadey but a different elm interface, could this be dud?
http://cgi.ebay.co.uk/ws/eBayISAPI....98448&ssPageName=STRK:MEWNX:IT#ht_4183wt_1139
i am having vagcom cable and HTC mega. i am not able to get connection and have tested all the available listed port. i am using the usb to mini usb converter to connect to my mega.
There's only 4 pin outs on a standard USB(VAG.com cable) there is 5 pin outs on a mini usb. The ground is pin 4 on a standard usb, the ground is pin 5 on a mini usb. Does your usb to mini usb converter allow for this, could be your problem?
i am not sure about that. maybe thats the reason. not sure. anyway to correct this?
i manage to get myself bluetooth elm327 but my handphone cannot pair with elm. do i need any driver. i am using HTC Mega
Problem "Data File Error" with Fes Mobile 2.0
Hello Yani,
I've got Fes Mobile 2.0 Registered with Windows Mobile 6.1,on a VGA Device (400x240).
In Demo Mode, trying to connect, I've no problems connecting to Lybra 1.9JTD (obviously I can't acces to my errors code of my car).
In Registered Mode, I've got same problems of Shadeyman, with "error exception"and "data file error",during connection.
Is it the same bug problem of VGA Device?
You solved it with a fix on Fes Mobile 1.0.1, but I can't find this setup...
Can you help me?Thank you :)
hi all,
im looking to purchase one of these... anyone any idea if there is a wifi version tried and tested... i need to use it on a doblo 1.9 jtd 2004
legepe
Hello everybody,
Somebody know if ELM327 OBD2 1.5V is compatible with my Fiat Bravo (The New bravo, year 2007). http://bit.ly/ZAjGrz
I'm very interesting to remove the 'Preheat Fault' message from my car, because I changed my preheating unit and Glow plugs but eventually the message still appear in my car.
Thanks in advance.
But i need full.. :cool:
Then you need to pay for it.... :)
You only need to have used its capabilities once, to have saved you spending a fortune at your local FIAT dealership. Surely, then it's worth it...? :confused:
If you use it frequently -- on your own or other's cars... -- then you'll make your money back in no time.... :D
