General Unidentified engine part
Bedfordshire Steve
Leighton Buzzard
Hi everybody, I have been lurking in these forums for a couple of years, this is my first post though.
I have just had an epic struggle fitting a new EGR valve to my Stilo '53 1.9 JTD, and unfortunately I snapped a pipe of from another part. What makes it even worse, is I have no idea what this part is. I think it is something to do with fuel return. Can anybody identify it for me? Thank you in advance for your help
Thats the fuel cooling/heating tank, basically fuel is pumped through it to stabilise the temperature of the fuel. Its held on by two long bolts (10mm head size), not normally a part which a dealer would have in stock as it doesnt normally cause any problems unless damaged by a tech (or owner).
Thats brilliant guys, thanks a lot.
What website did you find that part number on? Thats the same part I was looking at on ePER and it says the part is 46818882. The number you gave me is the correct on though I think
No, mine is a very pale green colour. there are quite a few in Dunstable, I see them going to work everyday. I saw a dark blue 3 door the other day, it must have been yours
Wouldn't have been mine. it is Jet blue which is a lighter blue same as the punto sporting. i will post pics up soon when i have got the suspension done. if you ever need a jtd for reference for parts or comparison let me know and i will try and help
Picture shamelessly stolen from Hitby's album as it is identical to my car. Thx Hitby:)
Actually i do remember seeing a pale green one about 3 week ago in the centre of leighton at the roundabout near halfords one lunchtime.
Hey all
Not quite an engine part but more an engine bay component, I did not want to start a new thread so I hijacked this one :p
I was having a quick wonders yesterday under the bonnet of my car and came across this part which was attached to my air box intake pipe:
Can anyone shed some light on what this part is? I could not physically pull it out but this box was very unsteady :confused:
Most likely a resonator to remove some frequencies or sounds in the air intake. If it is partly detatched (ripped off) from the pipe, it means unfiltered air enters the combustion chamber - dirt with it. You could rip it off, put a plastic cover over the opening, superfix it and clamp it together again.
Hi there Morty and thanks for your reply (y)
So this box thing was meant to act as a sound resonator? Bloody hell that is weird, the exposure that the box has left from being detached did not seem to leave a hole in the air box intake pipe. If it has then I will attempt to patch it up, mind you it should still be ok as the air still has to bypass the air filter in the air box right??
Hey all
Been there, done that! The duck tape beckons mate..!
https://www.fiatforum.com/stilo/280665-what.html
can i remove this black box and just connect the hoses by splice?
