borislavdj
- Jun 3, 2008
- 38
- 10
Hi there.
I have a problem with this symptoms: when in neutral or with clutch pressed down revs drop down below 500, usually shuts down the engine. It shuts down almost 100% if drops from 3000rpm or more. It happens while driving or standing in place.
I have solved a problem twice before buy following the "guide" for cleaning the inlet control valve, but doing it yesterday did not help.
Now, little difference is that car runs perfect, pulls etc. No problem with that.
When started, engine runs at 1200 rpm and slowly lowers as it gets warmer. No problem at that rpm rate, but as it comes to normal idle 750-800 rpms, problem starts.
I have noticed that inlet valve moves little bit easier at first few millimeters when pressed down with hand (finger). There is more opposing force when it is opened more. Is that OK?
What should I do myself before going to service, if there is anything to check?
Thanks.
Thanks.
