We have been driving the punto over the festive period as around town it is much more forgiving than the stilo when it comes to the infamous edinburgh pothole, to that end the stilo has been sat encased in a coating of ice for the past two weeks. Went out last night to scrape the ice off her and ready her for the trip back up the a9. After scraping the ice off i though id better check that she still started. She didnt.
Engine turns over quite easily, but will not start are they symptoms.
Far too cold to do anything about it last night so this morning i have doen the following and my poor feet are frozen solid after spending a few hours taking car to bits!
Went out to halfrauds to get a spark plug adapter as all my tools are up North (10mm btw!) (Fail)
Took coil packs and spark plugs out, and connected them up externaly, turned engine over to see if i am getting a spark at the plugs, we have 4 good sparks, so its not the ignition as such.
Took back seat up to try and hear fuel pump running, hummmmmmmmmmmmmmmm, fuel pump heard to run satis.
Disconnected fuel pipe at front engine bulkhead and turned ignition on, wooooosh, big spray of fuel.
So, i am getting sparks, i am getting fuel to the engine, so far so good (so why isn't it starting!):bang:
Joined three burger king straws that i found laying about and taped them together, insert into spark plug hole and suck, and spit and suck and spit
lots of black oily fuel in there, think engine has flooded, but is this a secondary symptom or the original fault?
Going to leave it an hour for the unsuckable fuel to evaporate off a bit (although its -1.0 degrees on the dash so its not going to be exactly evaporating quickly!) then try it again.
I will get home tonight by hook or by crook, but more than likely by the punto!:devil:
(Have put battery on charge for the hour just to top it up a bit too.)
