Comment
Guide Tools
<!-- google_ad_section_start -->Pollen filter - how to remove<!-- google_ad_section_end -->
Published by Deckchair5
19-02-2006
Difficulty Level: 1
User Rated:
Difficulty Level: 2
The pollen filter is meant to be changed at every service interval but it's only done as an additional customer expense and not included with the service. It really gets surprisingly clogged so reduces heater blower efficiency.
Thanks Surchr, chrisghz, GhostRider199, Peat, adamE and 10 others thanked for this post
Dislikes Shaun139 disliked this post
Contents
Old 16-09-2007   #1
ChrisMClark has donated!
Re: Pollen filter - how to remove
Newer pollen filters (according to eLearn) are actually snipped on the top and bottom so they can be folded to facilitate easier removal and refitting, and older filters may be snipped manually to aid this too. Tried saving the images but they save as some strange format so I can't post them up
Thanks shaggy100 thanked for this post
2004 Alfa Romeo 147 2.0 T.Spark, currently rebuilding the top end after a very dramatic breakdown.
Had a few Fiats before!
ChrisMClark is offline Reply With Quote Quote
Old 17-09-2007   #2
Greece
Got this from a bosch filter i put hope it helps even more
Thanks corcai, Beryl the peril, avcihuan, Peat, zebraman and 1 others thanked for this post
Likes corcai liked this post
1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr
Stilatos is offline Reply With Quote Quote
Old 16-12-2009   #3
Fiats since 1973
johnson550's Avatar
johnson550 has donated!
Its best to put some cuts in it to help make it curve without twisting it.
Name:	Cuts in Filter.jpg
Likes FiatStilo2001 liked this post
2007 Stilo Sporting M/Jet 150bhp
2001 Marea Weekend JTD 110bhp now 171bhp (Gone but not forgotten)
http://www.fiatforum.com/garage_vehi..._vehicle&id=24
He who works and does his best
gets his cards just like the rest
johnson550 is offline Reply With Quote Quote
Old 07-06-2010   #4
jim cooper has donated!
Changed mine today (2006 1.4 16v active aircon 5 door) and can confirm you need a 5.5mm socket, preferably 1/4 inch drive, to get the little screw out of the cover hatch of the filter. Also you would need to remove the plastic tray that stops assorted wiring falling down onto your feet from above the pedals. This has a side piece which obstructs the slot that the filter goes in and it is impossible to move it out of the way. The tray is only held by two plastic press studs and they will break when you prise the tray downwards. Dont worry, they are easily replaced with the type of button stud that you can get in packs at Halfords. Snipping the filter as previously described is still necessary in order to get it round the clutch pedal and steering column.
jim cooper is offline Reply With Quote Quote
Old 26-01-2011   #5
hi tried removing the cover next to the clutch pedal but the screws / fittings were just turning when i was trying to undo them. are they clips , screws plugs. any help would be good because i'm not getting any air out of the lower vents.
jqx81o is offline Reply With Quote Quote
Old 26-01-2011   #6
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
The panel is held on with plastic fir tree clips similar to this one. Give the panel a sharp tug and they should fall out.
Thanks jqx81o thanked for this post
Likes Settler11 liked this post
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 1.6 Ignition Coils (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 27-01-2011   #7
Quote Originally Posted by Davren View Post
that's great . thanks. do i need to replace them with new ones after wards.
Old 27-01-2011   #8
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Providing they don't break, you can use the same ones again but after a few times they may become looser.
Old 01-10-2011   #9
Mioght sund like a silly question, but in a RHD drive car, which side is the filter on?
ScouserInExile is offline Reply With Quote Quote
Old 01-10-2011   #10
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
The filter is in the same position for RHD and LHD cars and is accessed from the right side (when sitting in the car) of the center console.
Old 23-02-2013   #11
Completed this today using this guide and all I can say is, What a MASSIVE difference!! There was almost zero airflow before hand and the filter itself was completely disgusting with loads of hair and twigs etc. It was completely filthy...
It is a tricky place to get to but I found that using a ratchet and screwdriver socket attachment worked well. All in it took about 30 minutes and the filter cost a fiverů Worth a million pounds in improvement!
Cheers for the guide lads!
bbrm is offline Reply With Quote Quote
Old 08-03-2013   #12
The 2 fasteners on my abarth, on the drop down panel, if you push the centre pin of the fastener with a small screwdriver they pop out
alex298 is offline Reply With Quote Quote
Old 12-10-2013   #13
Just in case anyone with a UK (right hand drive) vehicle struggles:
The filter cover is right at the very back of the footwell on the driver side, I looked at it blankly for ages because it's quite well tucked away. There is a little bolt that you need to remove first, and you could probably do with taking the overhead wirecover off (above the pedals), but I'm not sure its absolutely necessary (didn't seem to be too much in the way)
The filter itself is very easy to replace though, took just a couple of seconds, once I found the cover that is!
Honestly hope this helps, as the diagrams didn't really point to where exactly it was.
erryn is offline Reply With Quote Quote
Old 12-10-2013   #14
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by erryn View Post
The photograph on page 2 of the guide shows exactly where the cover, and the screw and clips that hold it on are.
Comment
Guide Tools
(G) changing pollen filter wireless53 Marea 13 28-03-2006 12:50
(T) pollen filter on new panda? Nuova500 Panda 4 23-02-2005 19:19
(T) Replacing Pollen Filter splathead Stilo 3 09-11-2004 17:48
(G) Stilo Pollen Filter courtland32 Stilo 3 12-06-2004 04:29
(T) Pollen filter newportz Punto (Mk2/2b) 3 02-06-2004 14:10
