General Gearbox Oil - Punto MK1
Kalev
Stockholm
Hey!
Its time to change the gearbox oil on my Punto 75SX -99 (1.2 MPI, 8V)
I looked in the handbook what Fiat recommended back in 1999 :)
Tutela Car ZC 75 SYNTH
SAE 75W-80, API GL5, MIL-L-2105 D
FULLY Synthetic (Not Semi as some say..)
link: http://www.alfetta.dk/images/More alfetta pictures/tutela 75.pdf
The oil market is a bit different since 1999, so im looking for a good replacement to the Tutela because its impossible to find it here in Sweden..
The best i can come up with is Redline but witch one is more suitable for the Punto:
Redline MTL (70W80 GL-4 Gear Oil)
Redline 75W90NS (API GL-5, GL-6, MT-1, MIL-L-2105E and SAE J2360)
or is the Mobil Mobilube 1 SHC 75W-90 (Full Synth)
API GL-4/GL-5/MT-1
ZF TE-ML 02B/05B/07A/12B/16F/17B/19C
Scania STO 1:0
MAN 3343 SL/MB 235.8
Thanks!
Ok! I've been to a Fiat Dealer\Workshop but they dont use Tutela, they have Castrol only.. So if Tutela isn't an option for me, what would be the best?
WhiteSei: Wich one of 75-90, the Redline 75W90NS or Mobil Mobilube SHC 75-90
Cheers!
Ok, splended :)
The second thing that i have have in mind is the Swedish climate.. Its a bit different that in UK mabey! This winter for example the temp. dropped down to -35 ºC (-31 ºF) a couple of weeks.
So i need something thats good in winter like -35 below and sommertimes + 32 C if were really lucky :)
Hey!
API GL-4/GL-5/MT-1
Scania STO 1:0
Thanks!
Just a tip when doing this - don't follow the haynes manual torque settings for the drain plug, it will crack your gearbox before you reach it(n)
I used the castrol manual transmission fluid 80w -90 in UK climate and changing gear when cold is more differcult than before the fluid was changed. however when warm it slots into gears really easy with little resistance(y)
Hope this helps some(y)
(I did this on my 1.1L 5 speed manual 1997 55s 3dr )
