Hello,
Iam a medical student in Antigua originally from the states. My landlord is a very proud italian who had imported a fiat panda from italy 30 years ago. However, It has been sitting around the side of his house for the past 4 or 5 years. I had a crack at it one morning and got it started by lunch time.
battery was dead
tires were deflated
windshield was opaque
ignition coil had a rusty ground
starter had a rusty ground
ground from battery was rusty
hand brake was seized
things i have done to it since then
--abrasive polish just to bring back a little gloss
--drained coolant and replaced with 100 percent distilled water
--accidently stripped the stud on the starter...whoops--fixed with washers
--tread on one tire just...came off
--tested various components...re-wired the horn and alternator...everything works
on my days off i will roll the car into my garage and try to bring it back to a more reliable condition. i might have to rent a orbital polisher in order to bring some depth back to the paint...i also would like to remove the interior and clean! I might just paint the side sills, bumpers, and wheel wells with black paint as well.
few questions...
um...i dont know too much about carbueration...but i do know that its running pretty rich! are there any tutorials online about carb tunning for this fiat panda?
- i read a wikipedia article that said the seat covers are removable and washable...i could really find any way to remove those seats...was that article true?
and finally ---am i supposed to see the flywheel like this lol -- owner said he replaced the engine at one point (didnt do a really good job...everything is kind of messy---missmatched bolts---messy wiring etc.
alignment is off on this vehicle as well - anyone know how to adjust the toe on the front wheels?
this darn thing leaks half a ton of oil as well! what grade motor oil and gear box oil do you use in your pandas?
thanks guys! any crucial welds/areas on the panda prone to rust?
ohhhh oh oh oh one last question! the throttle is semi sticky/delayed. i stalled quite a bit when i would tap the gas and forget to wait for the revs to build before i released the clutch---is there a way to fix it or is this natural for carb vehicles?
battery was dead
tires were deflated
few questions...
