kvonk
- Jul 29, 2009
- 97
- 36
How we startend
The repainted seicento
OMP cage
15inch Speedline Montecarlo's with toyo proxes R888 semislicks
New sparco strutbar
New ballberings
New ta technix springs and adjustible camber plates
New wishbones with strongflex
Recoated rear axel with strongflex and ta technix springs
New rear ballberings and rear calliper update from a barchetta
New sparco r100 seats with pink LUKE 4-point belts
Supersprint collector - 100 cpsi kat - cch48 exhaust pipe - novitec duplex
Pink steering wheel
Crankshaft lost 0.4kg and is balanced
Flywheel 4.5kg and balanced
Pistons lightened and balanced
Steel top ring - cast iron second ring - 3 pices oil ring
Pistons put in the engine
New berings
Crank placeded
Oil pump
Oil pump plunger tunend
Oil pressure and themp
Adjustible cam pulley for 16v
Aluminium timing pulley
Intake
Head flowed
4x42mm open injection trottle body's
Dta s40 ecu sensors
mechanical cam followers with lash caps
Technical cam datasheet
CATCAMS 1901453 and Bigger springs and retainers
6-speed Punto mk2 gearbox conversion for seicento
OMP cage
New sparco strutbar
New ballberings
Pink steering wheel
New berings
Crank placeded
Oil pump
Intake
Head flowed
Dta s40 ecu sensors
