tardiscento
Hi people, had my gearbox out recently and having refitted it cannot for the life of me get the gears to work again. I have a 2000 Sei sporting spi. Everything was absolutely fine before i took it out and changed nothing bar the clutch and engine mount, have connected the gear select connections and it seems i now have to lift the reverse gear thing to get it into fifth but the gear lever won't go over to first and second. If i adjust the reverse gear selector on top of the gearbox (if the main gear select on top of the gearbox is in a certain position the reverse gear select will go down into the gearbox and you can turn it to a different angle) it will select first to fourth but will not, without a lot of force, go into fifth and reverse. Completely baffling me. Only undone them and took gearbox out so why won't it re engage properly?
Help very much appreciated
