Re: Fiat Brava Compatible Engines
So,in conclusion,the only availabe straight-swappable engine is the 1.4 Stilo engine (if the car has 2001 wiring) or are there any others?
In my country I have seen the following Brava models (I mean just as a confirmation for their existence in Greece,but I do not care about the laws,as the engine will remain unregistered,the car will be just a "normal 1.2 SX"
Brava SX (1.2 16V 81HP) <-- ours :slayer: haha
Brava SX (1.4 12V 79HP)
Brava ELX (1.6 16V 100HP/115HP)
Brava HGT (2.0 20V Turbo,but this one is 100% swapped)
Bravo HGT (2.0 20V N/A,from the factory) car.gr/classifieds/cars/view/4824838/
The following is from car.gr , a site full of used cars.
The one that seems the most appealing from those,seems the ELX 1.6.
I have found both 100HP and 115HP versions of that engine on that site,idk why. I have found some 96-97 models and a 03 one. Would any of these work without the wiring?
Look,the only problem is that we don't want extra cc taxes. Otherwise we would've just gone for a full swap,for example for a 20VT Coupe engine. However,we want it to be a pretty simple swap so that our mechanic can change the engine kinda quickly for the sole purpose of getting the car to ΚΤΕΟ,where they check the engine and suspension every 2 years so that the car gets a certificate for being able to be driven. And unless you have a friend there,you can get to pay much if you have an unregistered swap.
I would like you guys to give me all the available options so that I can discuss them with my dad and choose. We might even choose to swap a 1.6 forever,if it's not.. hot-swappable
Thanks a ton
Oh! I'll get a picture as soon as I can. Does the engine bay cover have to be removed for the picture? you can understand I'm a total newbie!
