Hi there guys
Note been here for a while, but back in the Uno fold!
So, here is what i brought, a Uno 60 with a Punto GT engine conversion.
I wasn't really looking for an Uno again, however this was absoultey mint! Never seen a welder, been waxoled religiously, was just too good to pass up...
Anyway, here are a few of pics of from the previous owner.
Pre conversion
Few pics showing how clean the chassis leg's were!
And a few of the conversion parts
And a few of the pics of how i brought it..
When i brought it, it had a few issues i wanted to sort, firstly a really unstable idle, and a few bits that i wanted to re-do to my spec. Firstly the fuel system...
This was how it come
Firstly, i got a Mk2 Uno Turbo fuel rail
So, cut off the fittings and TIG welded some AN6 Fittings on
I also changed out all the lines to 8mm nylon front to back
Next i needed to make up a mount for the FPR
Next up made up the lines and fitted
At the fuel tank end i replaced the original turbo tank with a baffled tank. The days of an undertank fuel pump are gone what with the invent of high flowing in-tank pumps
Old tank
Old vs new pump
New in-tank pump
And fitted
Next up was sorting a pet hate of mine, bad wiring...
Stuff like this
And after
Before
After
Next up was the engine loom, i wanted to clean up the engine bay, move the ECU and relays into the car and make it look clearner
Here was the loom before
Old plugs
Making a template of the original loom
Mid making
And done, lovely MIL spec connectors
ECU, Relays, Fuses, and Bar sensor moved into the car.
This was the location when i brought the car.
And after, tucked under the dash.
Sorted a few other bits while the dash was removed, fixing previous 'wiring'
Before
After
Also fitted central locking
Next changed a few other bits like the throttle cable as it was ropey..
Old and new
Next up was sorting the lack of any kind of ducting on the intercooler and oil cooler, seen the difference a well ducted design could make on my Supra so figured i would fabricate some up.
Before, you can see the gaps all around where the air would escape
TIG'd up some ducts from aluminium
Oil cooler
New ducts and stainless hardware
Next up i wanted to make an AFM mount as it was just floating about, so...
Picks up on original mounts
Also made up a cable mount
Also TIG'd up some new boost pipes to replace the original mishmash, also changed the filter to a stock air filter housing
Before
Making the new pipes up
ICV Spout
Swage the ends
Fitted and done
Last job was fitting a light grill i got from italy along with Mk2 Sideskirts
Pre conversion
Old tank
Old vs new pump
New in-tank pump
And fitted
Stuff like this
And after
Before
After
Old plugs
Mid making
Before
After
Old and new
Oil cooler
Before
ICV Spout
Swage the ends
Fitted and done
