I'm looking to replace the loom on my 1970 L.
I've been on the Ricambio website, they have a choice of two. One at £140 and none specified in its description. A second that is £250 and says it is for cars with the ignition on the steering column. My car has the ignition in the centre of the dash !
I spoke to Ricambio and they suggested buying the £250 and check to see if it would work ! If it does, all good. If not return it !
Has anyone used this one and found it has worked or did it require alterations. If so what did you do. Or can you recommend a supplier that has the right thing.
Many Thanks
David
Many Thanks
David
