General will these fit?
They certainly will not bolt on, as the stud pattern is 4 x 98 on an X, and without knowing the offset of the wheel it is a bit of a reach to say they would fit without spacers or guard work.
Being off a Jetta I would say they are a front wheel drive offset therfor not really suitable without hub adapters.
Without some serious surgery they won't fit - 10mm extra on the PCD is a lot to overcome. It isn't just the PCD - the wheels need a hub centric fit so the centre spigot needs to be the right size. The offset is probably the easiest bit to get around...
Hi Raph,
If you can find a set of these wheels which have come from a jetta the pcd should be 4x100mm not 4x108mm you'll probably find you'll also need a spacer to counteract the fact that the offset of the wheels will be higher than stock
In which case you could probably get away with using these
http://cgi.ebay.com/ebaymotors/WHEE...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
which would also solve the center bore problem as the spacer fits over the center bore of the hub completely
hope this helps
