General where my wiper fuse?
Don't do it, you will damage the bonnet.
Better to fix the actual problem, which is most probably that the latch assy needs to be moved slightly, either to right or left. Remember also please, that the two rubber stops at each side of the scuttle panel are there to stop the bonnet vibrating, not to compensate for a badly adjusted bonnet latch.
Rgds.
Rgds.
The springs do get loose (don't bend back to where they used to). I did fix it once and you need to ping it out and bend it the other way and then ping it back in.
I to keep meaning to sort it, I get cramp in my arm when I do my circus act!
If you've got long enough arms then you can open a dodgy bonnet by opening the drivers window, arm through window to pull the lever then use your fingers to lift the bonnet a bit on the side. Works for me :)
