Technical Wheel bearing?
Luisc
Portalegre
Hi guys, recently i am have issues with a noise from the front left at speed when turning left , i was wondering if it could be the right or left wheel Bearing and did then test , they seem to have this play any idea ?and did Record it , seems possible?
Or this play could be normal?
  • VID_20241117_112422.mp4
    39.4 MB
You can't tell by manually spinning the wheel?
Often when going around a left hand bend and noise more apparent then the problem is on the right hand one as you are throwing the load onto the right hand side in a left bend.
No i only ear the disc brakes , running nothing special, i noticed a brake pad wear indicador cable cut and and maybe it was touching something at speed , need to test it no that i trimmed it
