Technical Whats My Name?
mprowe
I have a 2011 registered Fiat Ducato. Can anyone suggest where I can get a wiring diagram?
Failing that, what is this plug called?
Regards, Martin
I think the eLearn should have wiring diagrams
Thank you Eklipe3k,
They sure do. Took some working out on how to use the eLearn software!! However, that solved, can you (anyone) confirm the point-of-view used in the Electrical Diagrams?
For example, the text from the E7015 (Alarm) Functional Description, says (First sentence):
"The Body Computer M001 receives the doors open signal, at pins 11, 34, 33 and 35 of connector C, for the left front door, right front door, right rear swing door and right sliding side door respectively."
So, where am I when I reference LEFT/RIGHT? The drivers seat looking forward or outside looking at the front of vehicle?
Simple question - but it make a bit of a difference...
Regards, Martin
Hi
I think they refer to left/right as from the drivers seat ...
Thank you FreeSprit,
You are confirming my suspisions! In my experence the "From The Driver Seat" is the common reference point.
I don't think LHD/RHD is relevent? At the drivers seat Left is Left regardless.
I think I need to open a new thread, this is moving off-topic.
Regards, Martin
