VP2 Engineering Mode
eggy43
West Sussex
I'm trying to get the rear speaker outputs to work on my VP2. I've found the guide on-line but I'm only getting sound from 1 rear speaker.
Does anyone have details of the codes used that I need to change the speaker set-up? Code change is from 6(0x06) to 8(0x08) - this enables the fader option.
I've tested the radio at the rear connector so that rules out the wiring. I suspect it's a fault with my radio but just wanted to check that the info I'd found on-line was correct.
If anyone has a VP2 with the rear speakers enabled, can you please check the settings and let me know?
