My Uno Mia (South Africa) 1400 1997 model, 4 Dr 5-speed is blowing oil like an angry volcano - first through the dipstick (It was pushing the dipstick out!), then when I added a piece of plastic paper to make the fit firm, it blows out the oil filler cap and shoots oil all over the place.
My local bush mechanic is stumped - he suspects the oil pump (we've cleaned the breather pipe, BUT NOT REPLACED IT - IT IS A BIT ON THE WORN OUT AND WHEEZY SIDE).
But then another, with a more formal training, suggests oil rings.
I've got a slight problem with both, thus my turning to this forum.
If it was indeed the former, then the oil pressure would surely be low? From reading on the net most oil pump failures for any car result in low oil pressure, and that of mine is certainly not low, it is VERY VERY high!
The latter - well - also from reading around, should also cause smoking - and that is not there - at least not notable. Can anyone PLEASE help?:bang:
I don't know if it's in any way related, but the carburretor leaks fuel a lot - one mechanic says it's the base or sitter or gasket or somesuch which needs attention and yet another reckons it might be overflooding somehow and then overflowing the excess fuel......
