Now that is interesting - applies to mk2 1.2 16v as well?You could fit the 1.4 16v engine, but you will have to be good with electronics & even then you`d still have problems because of the ECU needing a wheel speed sensor
Any other inputs essential to the engine management aspects of that ECU (excluding things like alarm/disabler), that for example my 70SX wouldn't provide?
Get serious boys !
The easiest way to get more performance is to get rid of weight.
So the driver hast to stick to a strict diet,
swap the spare tyre with repair fluid bottle
and remove the rear bench.
And not to forget ,remove all the unnecessary garbage in the car.
Give the carpet a good cleaning too :slayer:
Get rid of all that turbo nonsense, vented discs, heavy split driveshafts, brake pedal shaft, which add 120kg to a 'normal' Uno!
