Graham moore
- Joined
- Jun 23, 2015
- Messages
- 2
- Points
- 2
Ok chaps I'm driving from the UK to Germany in my x. Is there a headlight adjustment procedure or do i have to stick deflectors to the lenses??
For my 500X Cross Plus with Xenons then I've used beam deflectors.
Suggest you drive up to your garage door and put the headlamps on dipped beam. If you have a "kick-up" to UK Nearside then you really/legally/ideally need to block/alter.... that kick-up part of the beam.
This can be done with a dedicated kit or you can "self modify".
I go abroad every year and have only ONCE encountered a French police officer pulling UK cars when disembarking the ferry for not having beam adjusters.
To my knowledge the 500X vehicles do not have flat beams.
If you are not sure and not sure how to test then you can go to any UK local county council MOT testing station and they will willingly and freely check your headlamp alignment and be able to tell you if you have a "kick-up" or flat beam.
I suspect that the French authorities will, as they always have done whenever national relations with the UK get strained, be on vehicles leaving the tunnel/boats like a rash. Easy way to get some fine income and they love a bit of Anglophobia occasionally!
The kits cost like 2 quid. Don't forget to also buy things like spare bulbs, warning triangle, fluorescent jacket, etc which MUST be kept within arm's reach of the driver in the car and worn before exiting. And you must also have enough jackets for all passengers.
And a breathalyser kit!!
