Raise car, remove front wheels, undo track rod end nut and loosen lock nut on threaded section. Unwind and remove track rod end (note number of turns) and fit new one in reverse order. Carry out tracking afterwards.
it might be needed although if your replacing the item slacken the lower nut off then wind it back on till its 3/4 or so wound on the threaded stud
then bash it upwards with a hammer once loose then wind the nut off and remove the TRE By not fully winding it back on the nut protects the end of the tread from been burred over when hitting with hammer ensuring you can still remove the nut
