The Timing belts are relitively easy. The only difficult part is getting the crankshaft bolt loose.
1)Remove altenator drive belt.
2)Remove timing belt cover.All 10mm bolts and some are hidden behind a plastic cover on the front of the engine.
3)Loosen the crankshaft bolt depending on the model of the car. If there are 3 bolts around the crankhaft bolt, remove those and not the crankshaft bolt.
4)Behind the cover you will see your timing belt.
5)Alighn the marks on the crank and cam shafts. The will be a line on a tooth of the camshaft, alighn this with the very top of the rocker box cover. ONLY TURN THE CRANKSHAFT AND NOT THE CAMSHAFT.
6)Use a bit of white paint or tippex to mark a tooth on the pulleys with a solid part of the engine. These are to make sure nothing moves when you remove the belt.
7)Slacken off the belt tensioner and slide the belt off the pulleys.
8)Put a mark on a tooth of the new belt and one on the old one. And lay them on top of eachother so that the marks line up and go around the belt. If the lines do not line up (2 or 3 teeth away) it is the wrong belt. If they line up, it is the correct belt.
9)Refit the old belt, being very careful to try and not move the pulleys. Also make sure the slack in the belt is on the tensioner side of the engine and not the exhaust side. The belt should be pretty tight on the exhaust side of the engine.
10)Push the tensioner towards the belt to tighten the slack out if it and tighten the tensioner bolt.
11)Use a spanner to turn the engine over once and make sure your marks alighn once you have. If they have, the belt is on correctly.
12)To check the tension of the belt is correct. Put your finger and thumb on the belt and you should be able to twist it through 90 degrees at the longest point between two pulleys.
Now just replace your timing belt cover and your lower fan belt pulley. Replace your fan belt.
Start your engine, it should start fine.
NOTE: IF YOUR ENGINE IS VERY HARD TO TURN OR STOPS WHEN YOU TURN IT BY HAND, DO NOT TURN IT ANY FURTHER. TURN IT BACK AND CHECK EVERYTHING AGAIN.
Good Luck.
Pete
Pete
K&N Induction Kit On A Panda?? Never!!!
