Technical Temperature problem
no name
My temp gauge on bravo hgt is going like crazy, and the second speed on coolant fan isn't working. Fan works on second speed only when the air conditioner is on. Is this temp normal when driving in hot weather???
neither of my bravos got that hot.
if your radiator looks to be in poor condition then it will not be very effective. your thermostat could be stuck shut if the hose from thermostat to top of rad is not hot.
fan problems are common, especially on models with air con. rusty/dirty relay connections on the front of the battery tray are often the cause.
Today i found what is my problem, i have bad connection on (-). Now the fan works on 1st and second speed. But again the gaguge is going too far. So i decided to change thermocontact. My old thermocontat was working well, i have the blue one which open: first speed 87-92 and second speed 92-97 degrees. The new one is black and it open: first speed 83-88 and second speed 89-92. So with this thermocontrol is cooling good, but my fiat dealer told me that i have thermostat which open on 88 degrees and the thermocontrol shoud open 5 degrees more than thermostat. Anyway i am happy, the car is cooling. Thanks for reply :)
