Hi can I ask the best way to fit a new sump using silicon gasket seal, thanks
Sent from my iPhone using FIAT Forum
Hi,1.9 JTD it just uses silicon gasket ? Is it best to join them wet and leave to dry or spread the silicon around the sump thinly and leave to dry before fitting to engine
Hi,LOCTITE SI 5980 is a Silicone sealant.
I'm pretty sure most (if not all) Silicone sealants are oil-resistant too.
The reason I don't like it for 'gasket' use is the possibility of it getting into the oil, and blocking oilways.
If used sensibly/correctly though, it's pretty unlikely.
I have seen some pretty bodged uses of it, where people have just splurged it on in great dollops . . .
I'm sure some of you have seen things like this . . .
What I've always done is apply sealant
Tighten all bolts to just when they're starting to nip
Walk away at that point
Another nip up the following day to compress the set seal
Fill with oil and away you go
I don't necessarily know if that's the right thing to do but it's always worked for me
I like to think of it as making a gasket and then compressing that gasket
I'm sure I'll get told off if I'm wrong?
But I m not changing what I do when it works
