Hello. I hope someone checks this topic and can give me a usefull advice
Here is the problem.
I have a '94, 1.2 Fiat Punto and after about a month or two of sitting in the parking lot I decided to put it in the garage. It was sitting on grass and some weeds were growing under it. No prob. I said, put the key in the ignition, started the engine, put it in reverse to get out of the place it was parked. At first try the engine died, try 2, put it in reverse, reved the engine a little and after about 5 seconds a cloud of dense white smoke with a burn smell came out from under the bonnet. Stoped the car and the smoke cleared after about 30 seconds. I towed it to the garage and after 3 days i tried to start it, it started but the alternator belt snaped (the belt looked like crap, like it was burned, plastic like). I replaced the belt about two days ago, started the engine, the alternator is charging well, engine seems to run OK but there is a little burn like smell comming from under the plastic engine cover.
Questions:
1. What could be the cause of the white smoke?
2. What should I check so I can use the car safe without staying with an extinguisher next to me
3. What is the cause of the burn smell comming from under the engine cover? Could it be some smell left from the white smoke?
4. Can an old alternator belt be the cause of the white smoke?
5. How concerned should I be?
Please excuse my english, I am not from the UK
Thank you.
Questions:
Thank you.
