Hey all !
First of all, let me apologize if a similar topic was treated before. If it has, I couldn't find it, and I would appreciate if someone were to redirect me onto this said post.
OK, I have a project to build a quite 'hot' Fiat 500 (the original one). I own a 1975 Fiat 500 R. Here are the questions I'm asking:
1. What are the biggest/largest/widest wheels that can be fitted to the original, with the standard wheel arches ? And with larger wheel arches ?
2. What are the largest brakes that could be fitted within those wheels ? Do you have a recommendation on which would be a donor car ?
3. What type of suspension do you recommend ? Progressive ? Is there a particular model ?
4. Is it really worth £600 to fit a 750cc cylinder kit ? Can it be fitted to a 126 engine ?
5. How much power/torque can a 126 BIS gearbox handle ? a 126 transmission system ?
6. I'm looking at figures up to 150bhp, so what is the strongest gearbox/transmission that can fit in the 500 ? Is there a kit ? Does it have to be hand crafted ?
7. Which carb' replacement do you recommend on a 126 engine ?
I'm on a limited-ish budget, meaning I don't want to spend 7656825 thousand pounds on this, but I can stretch to around 3 grand. I'm also exploring the possibility of making an Abarth replica, and I was wondering if there was any kit or website from which I could buy the wider panels, and the boot lid.
Looking forward to hearing from all of you, any comment/advice is appreciated !
