Technical seicento michael schumacher p1300 trouble code
Hi, does anyone know what the p1300 engine code means?
Looked online but not much help.
P0300 is general misfire
P1300 is phonic wheel learn. i.e. engine hot , rev to around 3000rpm, release throttle, repeat. light should go out.
Actually is light on ?
Well I typed that into word translator and it came back 'learning target ' so it maybe something to do with the phonic wheel on the cam shaft. I used the fiat ecu scan earlier and tried resetting it see if it works. Ill see if the code is still there tomorrow., if it is I'll try changing the cam sensor.
http://translate.google.com/translate?sl=auto&tl=en&u=http%3A//www.ammirati.org/forum/autoriparatori/errori-dtc-obd/codici-errore-obd-ii-gruppo-fiat-sistema-dpf-t5257.html
This is the website you gave me fingers, but its been translated into English. Maybe a good Idea to make a sticky so people can diagnose their trouble codes? Just an idea like.
Linking shouldn't be an issue -- but maybe the Mods could take a look at the idea? Might need permissions from the site were FF to re-use it.
D4nny8oy describes the proceedure at post #3 here, so, with luck. you'll not have to replace anything, or even open the bonnet.Similar to what Mal says earlier, but more revs!
Well I checked for that code today and its not coming up anymore. Also the car has done 70,000 odd but according to the cars ecu its only done 50,000 km . The only thing I can think of is, its had a new ecu and wasn't calabrated properly by revving the engine and holding it there for a few seconds 2 or 3 times that's why the code was there and wouldn't go until it was done properly.
