Punto (Mk2/2b) relays
trevvennard
Hi all,
I am trying to get a 12v 20amp 4 pin relay for my wife's 52 plate 1.2 8v Punto. Does anyone know where I can get any or can I use a different amp age like a 30A one. Having a problem with the dipped headlight on the passenger side so was going to try changing the relay in the cabin first before I start changing things like the stalk on the steering wheel.
Hi all,
anywhere. they are pretty standard, a 30A will do as long as is higher than whats in and same pin location will be fine
Hi trevvennard,
I have the same issue with the passenger dipped headlight only the indicator in the same cluster doesn't work aswell,changed the bulb checked the fuses
This has now been fixed, it turned out to be corroded connector on the earth wire at back of headlight, there was another pin to put earth wire on which we have done and the headlight is now working ;)
