Technical Rattle on Startup?
Quite south.
Last couple of days, starting from a completely cold engine for about a second or two once the engines started theres like a rattle (clutch always depressed when engine started so not gearbox). I checked oil on dipstick, apart from being darker in colour than usual (not sure if I should read into this) its about 3/4 full. The noise completely stops and remains silent once the engine is running and driving. Starting the engine when its warm doesn't cause the rattle either.
I wouldn't usually worry, odd rattles and noises are pretty normal but its not a nice noise at all, I don't know if its something like oil pressure not getting oil to the top of the engine quick enough? :confused:
Its probably down to oil draining out of the bearings overnight, then you will get a brief knock / rattle until pressure builds up and the oil starts to circulate. Might you be due an oil change ?
