lordthomas
Hello!
I have been suffering from one (or more?) faults for more than a year and the mechanics can only guess (not with much luck
). 2016 1.4, 120hp, 100k. km, (940B7000) produces the following phenomenon:
1. After a long standstill (about half a day), if I start the engine and it runs for 5-6 sec, the check engine light stutters, the car shakes and the check engine light flashes for 10-20 sec. The issue comes when starting for the first time after 10-12 standstill (If I stop the engine after the first start and start it again, there is no issue). According to diagnostics the following error codes has the car: P0300-301,302,303,304 and P2097. (Random misfire, cylinder 1-2-3-4 misfire, upstream lambda probe). The check engine blinks for about 5-8 seconds, then the error disappears and the engine runs smoothly.
2. Sometimes after the first start, the check engine lights up continuously, it is also present as a residual error. I have already replaced 3 times the spark plugs (all 4 of course) and lambda sensor. The continuous Check engine sometimes only comes back after 2-3 months, but it's always the same error code.
Also the end of the exhaust pipe is very sooty.
So far:
I would be grateful if you have any idea what cause these issues.
Best regards,
Tamas
So far:
- The lambda sensor has been replaced with a new one.
- The spark plugs have been replaced with new ones 3 times.
- MAP sensor has been replaced with a used one and after that with a new one.
- Battery checked
- Fuel sensors and fuel pressure checked.
- Engine compression checked
- Fuel injection checked
Best regards,
Tamas
