- Joined
- Apr 5, 2020
- Messages
- 15
- Points
- 54
Hi, bought my parents a Fiat Qubo each, to replace their Pandas which they had both started to dislike. Ones a 2011 which ended up needing a timing chain, that's fine. Got the funky green 2009 one out with the old style multijet engine (looks similar to the Panda engines), MOTd it then got it in for a service. Everything was going fine until I changed the fuel filter, now it won't start.
Fuel is getting to the high pressure pump but nothing past that, except a dribble to the injector furthest from the gearbox. There's no fault codes, so I thought maybe the high pressure pump had failed so I swapped it over from a spares Qubo I bought which I knew ran and it still wouldn't start. Fitted the pump I removed to the spares Qubo and that starts fine.
This green Qubo will start and run on small sprays of easy start but then cuts out and won't restart
It sounds like a bad air lock but I've never had an issue before on the Pandas. Maybe I'm comparing it to a Panda too much. If anyone's experienced similar I'd love to know what to do. Very close to pulling it round and round in second gear and if that doesn't get it going making this green car my spares car and fixing the other
Cheers,
Eathan
Cheers,
Eathan
