Technical Punto 2002 Lock Set
seankin0123
Hi everybody iam new to this forurm so be nice to me :)
right i will start i have just got a 2002 punto 3dr elx with no keys iam trying to replace it with a second hand set, i got the lock set along with the ecu what more do i need to get it up and running ??? thanks
hi
elx has abs
be sure to buy the second hand ecu and main body fusebox and bsi behind dash of another elx or your speedo will go nuts
so
you need
ecu off engine
key and ignition barrel
fusebox and attached box from behind dash where your right foot is if in a r/h drive car
ok?
do not get bits mixed up in case you lock them out
do not remove components without battery fully disconnected
Hi i have recently done just this, can make a guide if you'd like?
