Yellofrankcar
After (23) years of doubting (yep first owner), I would like to see if it is possible to upgrade the front brakes of my '97 Barchetta. :wave:
Prevision is that the upgrade must fit within the 15 inch original rims.
This because in Belgium it is not allowed to mount different size rims (MOT rejection).
I also want the new front brakes to be barely distinguishable from the original, this to avoid annoying comments during the yearly MOT.
After a lot of research (thanks to COVID-f****g 19
) I assume it is obvious to base the brake upgrade on the well-known 281/26mm discs or the even more common 284/22mm discs and corresponding calipers & caliper brackets.
My "fear" is that there is not enough space to mount an adapter as the holes of the steering knuckle are, very likely, to close to the holes of the caliper bracket.
Does anyone have any experience/ideas with this potential upgrade let me know.
Any comment, question, remark, idea etc. is welcome!
Have looked at most barchetta/punto fora but couldn't find a similar solution.
For clarity: I'm not looking for a track day high performance front brake upgrade but merely a standard looking, better performing brake upgrade (better performance and a much better fade resistant brake for in the Italian dolomites).
Regards,
Frank
Regards,
Frank
