Technical Power Steering and ESC Issue
lewispunto15
Manchester
Hi guys. I have a 2015 Fiat punto pop 1.2L. Battery has been changed. Over the past year I have issues with the power steering and the ESC.
Firstly the majority of the time when I press my brake, the ESC becomes unavailable (warning light comes on) and then when I press my brake again it activates again. This happens repeatedly but sometimes it doesn’t happen and sometimes it stays on throughout the journey.
Another issue I have is when it’s been cold (4 degrees and below) when I start the car, the power steering warning light comes on along with the ESC being unavailable. The power steering is also heavy. What I have been doing is letting the engine warm up, turning the car off and moving the steering wheel and restarting the car. After a couple of attempts doing this and restarting the car, the fault disappears.
Any advice on what the faults could be?
Model
Punto Pop 2015 1.2L
Year
2015
Mileage
55000
0. You've started 2 threads (different titles, but same content), erase one, now.
1. SEARCH. Multiple existing threads about power steering cutting off etc.
2. Basics to rule out: alternator, battery, main ground/earth leads.
3. Only then you can mess with the steering (sensors, column).
