um i dont think its quite that low, or id need a 4 farad cap for my 4 channel head unit...and they tend not to come higher than 2 farad, (obviously there are exceptions, like the Audiobahn [FONT=Arial, Helvetica, sans-serif]
ACAP651N, which is 12 farad) and they are far from useless...here are two paragraphs from two diferent high end audio company sites:-[/FONT]
1) Vented Innovative Bass Encolsues (VIBE) said "A must for any high performance subwoofer system.
The VIBE 1.5 farad power capacitor is a must for any high performance audio system. VIBE¹s 1.5 farad power capacitor bridges the gap between the vehicles battery and the amplifiers ensuring rapid smooth current flow resulting in louder tighter bass and clean crisp midrange and treble.
The built in digital voltage display constantly and accurately displays the systems DC voltage. An all new VIBE power distribution block is built into the top of the capacitor to allow easy wiring into the system. amplifiers may be wired directly to the capacitors distrubution block.
- New 1.5 farad capacitor has 50% more capacitance than the previous model
- New power distribution block allows 2 x 4 AWG negative inputs
- 2 x 4 AWG positive inputs and 2 x 8 AWG positive inputs
- Accurate digital voltage display with auto turn on/off
- Lowest ESR of any capacitor on the market today
- Can improve low end bass response in car audio systems.
[*]Ideal for large bass systems that typically struggle with poor current delivery from the battery."
2) Audiobahn said "Though amplifiers already have internal capacitors, their size and capacity is limited to keep the amplifier more compact. External capacitors help to deliver power when the audio system places severe demands on the electrical system of the automobile. They are designed to store power to be made available to the amplifier under extreme current draw. Aluminum capacitors have very fast charge/discharge times. Carbon cell capacitors have a higher capacity in a smaller design. The ACAP651N combines both of these technologies to give you higher capacity in a smaller form without losing charging/discharging times. Audiobahn also offers a traditional aluminum 1-farad capacitor with a choice of standard connection terminals or distribution blocks."
Hope this helps you Jonny!
az
