Technical plug gap
Technical plug gap
kbj1962
hi does anyone know the spark plug gap for my 1.2 pop am putting in ricambi ones.
cheers will not bother buying feeler gauge
A feeler gauge is handy if you have butter fingers and you let a spark plug fall on the ground.:)
Below is the recommended NGK plug (the only one that is covered under Fiat warranty).
http://www.ngkpartfinder.co.uk/car_commercial_search.php?type=SPARK%2520PLUGS&manufact=FIAT&model=500%2520%25282008--%253E%2529&engine=1.2
http://www.ngkpartfinder.co.uk/car_commercial_extra.php?id=6294
The model no. ZKR7A-10
http://www.fiat500usa.com/2010/02/inside-fiat-500-spark-plugs.html
For the 1.4 L 16V version of the Fiat 500, NGK’s DCPR7E-N-10 has been selected as Original Equipment. This 12mm spark plug has been developed specifically for the FIRE MPI engine family. It is also a nickel alloy plug with a gap setting of 1mm.
One of the reasons Fiat chose the DCPR7E-N-10 plug is because its small diameter makes for easier installation in multi-valve small displacement engines. Another reason is its good ignition quality without requiring the costs of precious metal and its robust ground electrode design.
