Technical Please help, I'm lost ?
zooooom
1.4 tjet, misfires, changed all coil packs and plugs. Had the same problem a couple of months ago, changed 2 packs then and 2 today. I can unplug coil pack on cylinder 1 and the engine misfires the same. I don't have a code reader which is a bummer
You really need a code reader to make life easier and is useful in the future. A fake autel unit costs about £13 on the bay of e.
Have you checked for a spark? Have you had it diagnosed before?
Start simple and check spark. if you have that in all cylinders then they are fine. Check plug gap aswell incase its been moved.
Thanks for the reply only just seen it lol. I ended up messing for a while, I checked the spark ( and got a shock at the same time) it seemed fine, so then I was thinking injector but that was fine. In the end it was the plug itself. I didn't think it would be that as they've only been in a month! The garage I used last time put the wrong plugs in!
All sorted now tho ???✌?️
