You will need to look for the sidelight wire, it should be under your steering column, or at least it was on mine.
Get a tester (forgotten the name) with the bulb in the middle that lights up when you hit power, then turn on your side lights and then test to see if power is running through it.
Hard to explain as mine is a mk1 and places are different
