Desperately seeking a fuel tank and all the integral (why?) filler pies etc. for a 2013 Panda POP. 1.2 (69)...It seems squirrels like the taste of the plastics been an ongoing issue. The part(s) is impossible to track down via FIAT.
It’s worth contacting these guys as they are often able to source parts not listed in their website, at prices well below those of a dealer https://www.shop4parts.co.uk/
Hi thanks for that - generally better than usual sites, however the fuel tank and filler pipes etc. don't seem to be under any of the categories that are listed - I can't even get a parts number out of FIAT - very frustrating
I was suggesting you call them anyway. Someone in here bought a replacement steel under tray for their 4x4 Panda from S4P. Even though not listed on their website, they still were able to supply it, at much reduced price. They’ll find the part number for you.
@Jock R take a look on the bottom of the fuel tank - as the part number is moulded into the plastic. The photo is of my tank, but note this is a 4x4 and so the part is different (it’s shaped to fit the propshaft for the rear drive). There are two numbers, and then an x to mark B (benzine, or petrol) or D (diesel). Most of the plastic parts on the car have the number moulded in, and many other parts have it on a label or stamped into the metal.
... and, the filler pipe and breathers etc (which are separate parts) are shown here (although the main pipe, part '1', isn't listed. Oddly, that *is* listed for the diesel version - but that will be different owing to the different filler nozzle to ensure correct fuel is used. that's in the second (attached) image)
