Hi John H., I preferred to open a new topic to discuss about "our" ECU...my own car's equipped with Bosch Monojetronic Spi injection...and I found a .pdf file on the web which seems to be helpful for car repairers
!There are described all the ECU types, Bosch, Marelli,Siemens, Delphi and Ford EEC
!You can find how to do measurements and the values for tensions,resistances and pressures recommended:I...the only problem for you is that it's written in italian, even if the technician language is easy to translate!
About resetting Bosch ECU...I know it's sufficient to disconnect the battery for atleast 5 minutes and the operation is done[8D]!Then reconnect the battery and turn on the engine without touching the throttle...wait it warms up till the radiator fan switches on!After this you need to do a little round (10km are enough) to let the ECU auto-learn your own engine parameters...this is the description I found in the document I told you!
