I want to do an engine conversion on my Cinq.Fit in a Punto 60 1242.
Ive found the Panda 1.1 is a FIRE Engine- it shares a gearbox with a Punto, Cinq Sporting and Sei...The 1.2 is also a FIRE Unit- so is a bolt for bolt swap.
My Cinq is a 900cc model though, so it'll be a bit more complicated. I will need a new ECU in order to run a 1242- as my 899 will not do this- I need a 1.1 ECU at least (Cracker reports the 1.2 runs fine on a 1.1 ECU).
ECU's are a bit hit and miss...most Puntos are immobilised by coding in the ECU, The ECU in Panda's and my Cinq is not coded like this...
To do this convo' successfully, I will need a 1108 FIRE Panda ECU, but I'm finding these cars VERY Hard to find...ideas where I could find one...I could also use the gearbox amongst most other bits!!
Arse
Ill think of something witty....just wait and see............wait I might not.
Arse
