Technical p0203 p0201
Sanyi0127
Hungary
Hello! I'm struggling with the following error codes->
P0201, P0203
1.6 16v 182b6000 engine
I've done pretty much everything that could cause the problem, it's weak while driving, jerks, and has difficulty accelerating
I've struggled with this error once before, and the error was resolved after replacing the spark plugs /NGK BKR5EZ/
I've outlined it, I've checked the wiring harness completely, and I found everything to be fine
I cleaned the injectors, their resistance is uniformly 14 ohms
The injector harness wires were hardened, they got new wires and terminals from connector to connector
I tried replacing the injectors, transformers, and finally I replaced the spark plug set, although we have 7,000km on it, and I know very well that this will make them last longer
It doesn't suck in farts, the throttle valve is clean, it was replaced 1 year ago (new)
Map sensor is clean, upper lambda sensor half a year old
Engine control unit 1 year old refurbished
The connectors under the fuse panel are all clean, including the D4 connector
I'm clueless, I accept all help
Thank you!
