Technical Oil level sensor position and fix
EraseR
I have read this post, and I have familiar problem on my sedici.
Sometimes is on, sometimes is of (oil level is ok Selenia 20k)
Please if someone have a position of the oil level sensor on Tipo 2.0 16v and which pins or color cable are connected to ECU. How to fix it?
If someone have pdf of sedici electro wiring send me on mail or pm, I will put this docs on my FTP for everyone.
Thanks!
oil sensor is not connected to the ecu, its only to the dash (car loom), the pressure sender is the round thing by the filter with a single wire - its a variable resistor to ground and crap. The level sensor is just infront of the main pulley, sure this is a switch to ground and not a whole load of use. I'd get a capilary oil gauge to the filter then regularly check the level manually.
rich
Please post a pic.
Is this oil level sensor? :idea:
hey thats a pic of my engine - like my trigger wheel:) .
the one on the right is the oil level sender (this is not oil pressure) the coupes do not use this fitting, probably because it is rubbish, mine is not connected to anything. FYI the thing on the left is the crank sensor that is the main input for the ECU. Oil pressure gauge is far more important.
Rich
