Oh No!!! Major welding for MOT!!!
K
Karl
Hi All,
Apologies not been on for a while, had a sh**e last few weeks with Car...
Have been preping for MOT due 11th August and found the N/S wishbone covered in I guess brake fluid but cant find a leak so unless its from a previous spilage... then my attention comes to a bit of rust on the N/S front jack point on the sil... bit of a poke and whoops my four fingers went through the floor plan hmmm i thought 5\6 inch plate should do the trick only until lastnight i goes to my friends to have it welded and a bit more of a poke and 5/6 inch plate turns into 18 inchs from just behind the jack mount all the way to the corner at the wheel arch.... i just hope this will pass its MOT now
Sly Si - Sorry not been in touch re the Brembo's had me a few problems with the car as above that are priority...
I had exactly the same on the Marea a year back, both sides had gone through due to the jacking points being crushed.
Plated them up, sealed them over and passed the MOT :)
good luck!
Darren, did you flatten or reshape the bit that the standard jack sits on.... also did you weld the plate from the floor plan and up on to the outer sil??
I'll be sealing it up with the under body stuff at the weekend...
Thanks for the reply...
Ha those pics are like looking at my car last night.... I just hope i can get mine looking as tidy as yours...
7K
David Slaney
I
726
IMC63
I
A
1
11K
Angelo
A
