G Giovanni seicento Member Joined Jan 23, 2020 Messages 24 Points 56 Jan 10, 2022 #1 Hi.can anyone tell me what I'd need to read codes on an old 899cc.it seems to have a three pin connection and not the newer obd socket.thanks
P Prawny12009 Member Joined Nov 13, 2019 Messages 134 Points 81 Jan 11, 2022 #2 Multi ecu scan software , obd to usb cable, fiat 3pin to obb adapter. Diagnostic machines from eBay on, launch, autel etc etc will read cheers with the correct adapter cables. Older snap on readers that take cartridges are cheap, so long as it comes with the correct cartridge and cable that could be an option Otherwise you need the marreli diagnostic scanner used by fiat.
