- Joined
- Nov 29, 2012
- Messages
- 66
- Points
- 69
Hello learned friends, need some help with OBD2 codes (or lack thereoff) for which the search function didn't provide an answer.
2007 Ducato 2.3 JTD and XXLtech (NX200) OBD2 reader.
I'm living in Switzerland at the moment and my converted Van is due its biannual health check which is similar to an M.O.T only stricter. A lit engine management light, as is the case with my Ducato, is an automatic fail.
Bought the above reader and did a few tests but I am stuck because there appear to be no stored trouble codes.
This is the procedure:
1) Start a scan and wait for it to complete.
2) LCD display shows System status - codes found 1.
3) In the Diagnostic Menu I select read codes.
4) LCD display shows Trouble codes - no codes found.
Whats up? I did clear the codes before the last trip and stop/started the engine several times and everything was fine. I left it standing for a week and the engine management light lit up straight away. Several OBD scans provide the same results as before.
Can anybody help?
Can anybody help?
