General Number plate light failure warning?
rubadub80
Hi everyone. A few weeks back I noticed I was getting an intermittent warning light on the dash and a "check number plate" warning. It came and went but the lights were working fine, for the last week the light has stayed and the lights are not working.
I took the bulbs out to check and they seem fine, no noticeable breaks but still don't work. Unfortunately I don't have spares to try at the moment so don't know if it'd help.
A bit strange that they both don't work. Has anyone experienced similar?
I get the same thing every now and again. its only ever about number plate light though, no others.
theyv always worked though, so im guessing it may just be an intermittent earth point perhaps.
d
Its worth trying new bulbs. They are cheap off eBay, can get a box of 10x W5W bulbs for under £2. They may fail quicker than most, but who cares?
Dont buy LEDs. Even the "error free" ones trigger the bulb failure warning. I tried a couple of different ones, and a dummy load device, but neither stopped the bulb failure warning. In the end i went back to normal bulbs.
I had bad contact between the bulb and the socket, and between the connectors.
I also had a bulb (this one was on the brake) that had a broken filament that sometimes still made contact ..so the bulb would be ok and at the first bump in the road it would be out again.. etc
Basically get it checked out, 1 bulbs, 2 connectors.
Ah yeah, I am sure you recommended those to me, and they didnt work. In fact, worse than that, the number plate lights would go out after 60-120 seconds!
Perhaps the electrical load was too high, so switched off.
BTW, the downside of the dummy load resistors is that if you get a poor contact and your bulb goes out, there is no warning to tell you:mad:
Sorry for the delay in getting back to you guys about this,nthank you for all the replies. Gonna get some bulbs later as the old bill are gonna be hot on pulling people over the next week or so.
Right so I've just fitted the new bulbs and made no difference, still no lights and same message on dash with the bulb symbol.
Don't really know what to try now as there doesn't seem to be a fuse that controls it, or is there?
I've looked through the manual, and there is no reference to a fuse for number plate lights. However, as they come on with side lights, its likely they are on the same fuse. I'm sure they must be on a fuse!
See the attachment for eLearn's fault diagnosis.
  • side - number plate lights.pdf
rubadub80 The number plate lights have an inline plug for them where the cars wiring loom connects to the bumper wiring loom, it's on the drivers (RHD) side under the crash beam iirc. This might have before detached possibly? Seems plausible if both bulbs are failing to light. Do your fog / reverse lamps work :confused:
Access might be tricky, I suspect it'll be bumper off (I know know of this wiring loom as I found it when I removed my rear bumper to fit my towbar).
Alternatively you might succeed in locating it by removing the lower securing screws / nuts and prying the bottom part of the bumper slightly to gain access.
Here are some pics which may help, I've two plugs as I've rear parking sensors, one if for the sensors, and the other for the number plate and fog/reverse lights iirc.
