Hi, Thanks for this great forum. I'm a newbie and hoping you can offer me some advice and guidance
I've read several threads about noisy front suspension as this is a problem affecting our Fiat 500 Lounge. It's an 09 plate and we've had it from new - approx 55k miles. I've also read the front shock absorber replacement guide....
But so far, none of the threads have answered a burning question I have
Q1
What I've never understood is why the top of the shock absorber seems to be free to move around in the oval hole of the body shell. I always though the top of a shock absorber should be securely located. The way it can move must contribute to noise on uneven surfaces, mustn't it?
See picture.
I know Fiat came in for some stick with the early 500's and presumably they made some improvements.
Q2
Is there anything I can do to upgrade to a newer/ better factory spec?
As one of the dampers has started to leak I plan to replace the dampers, top mounts, and bump stops. I may do the drop links too, if it's obvious they are past their best.
Q3
What else should I replace while I'm about it?
Q4
Finally, I need to buy the key tool to stop the spindle rotating as I do up the nuts. Does anyone have the details of what I need?
Sorry for so many questions for my first post, but I'm hopeful you've got all the answers!
Many thanks
Q1
See picture.
Q2
Q3
Q4
Many thanks
