oOLISLEOo
Hello all!
I seem to have an issue with pump not kicking in,
The relay seems to work, but doesn’t at the same time, you hear the click and when I removed the outer over you can see the relay make contact but it does not engage the pump?
I ran a wire from the relay pin to the battery and the pump works fine, pressures the rail and the car runs perfectly
Any ideas where to start before I jump in double footed
- Model
- Cabrio 1.6
