Ok i got a bit bored lol so i thought i would do a little guide. It may not be needed but hey ho.
I thought i would show you how to cut out a full product but the same basic principle will apply for anything that you want to over lay.
Step one
Choose your photo (In this case a rather boring train)
I have then added a solid pink layer underneath.
Step 2
Add vector mask to your photo. (3rd Icon in from the left at the bottom of your layers pallet)
Press x to bring black to front if it isnt already.
Select the brush tool (in this instance i am using a brush size of 15 and hardness of 25%.)
Start to cut out the parts that you dont want i.e background. I click my first position and then go round the product holding the shift key. That way when you click on another position it will follow the click before in a straight line.
You will end up with something like below. Notice that you can see the colour of the layer beneath. Then if you forget to brush on your layer mask it will be a different colour.
Once you have gone round the whole of your object alt click your layer mask and it will black and white out your image. It is important that the black line is closed for the next stage.
Select the white areas that you want to delete with your magic wand tool. Then go Select > Modify > Expand. Type in a number around half of the brush stoke. Then press Alt and delete to get rid of the unwanted white leaving you with something like this.
To get back to normal view just click on any true layer in the layers pallet.
Simples
Ok so you dont like the colour of your train (because everybody hates the colour of their train
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So Create a duplicate of the train layer with its layer mask. (Hold Shift and drag train layer upwards)
Then hold down the alt key and select, selective colour from the create fill or adjustment layer button (4th button from right at bottom of layers pallet)
Click use previous layer as clipping mask.
Press ok.
Then click colourize
And play with the Hue, saturation and lightness.
Select the whole artboard with the rectangular marquee tool and delete out (turn black) the whole of your new colour layer.
Then use the white brush tool on your adjustment layer to put the colour over the top
Oh no's i here you say i have gone over the edge.
Have no fear this is easy to sort.
Apple (or whatever the hell apple is on a PC) Click the layer mask on your original layer. This will create a selection.
Click on your colour adjustment layer, layer mask. Go Select > Feather > 0.5 pixels
Apple + Shift + i to inverse selection then Delete or alt delete depending on what colour you have in front in the colour pallet.
Obviously i have way too much contrast on my colour adjustment layer. If anybody wants me to do a guide on how to accurately colour adjust and match then i can.
